It's Time to start shipping some Dredds!
I will begin notifying those on my list later today. If you know you are on my list and no longer interested, please let me know. I still have a lot of ramps to make, but I have a good deal already to ship. What people order will help me adjust production to fit the needs.
Regardless of where you are on my list, if you want to let me know what you want, I would appreciate that a lot, again so I can adjust production.
The first thing I noticed when removing the ramps from my own game is that they were very fragile. I immediately made the decision to make all of the Dredd pieces out of my thicker (.150") plastic for greater strength and durability. I think the most fragile was the big ramp. When I removed it I had to be careful to support it as I thought it would just break in my hands! In addition to making them out of thicker plastic, I also corrected some items and where I could, I left more plastic for strength, particularly at mounting points. Although I ended up destroying my own ramps in the molding process, they were in very good shape for making the molds. The only actual breakage I had was at the big ramp right side exit. The mounting tab had broken off and this is one point where I left more plastic for strength. All in all I am very pleased with the results of all of the pieces.
One other thing I noted that I would like everyone to check when assembling the pieces. On the Big ramp at the center Exit (to Dead World) the two brackets at the exit I found to be a little tight with respect to how they fit, specifically the top edges where they meet the underside of the top edge of the ramp. I checked the fit against the original ramp and it is was also tight. Once the pieces are riveted to the ramp, I feel they will put additional stress on the top edge of the ramp. So, I will be shaving my own bracket tops down about 1/16".
The ramps are being offered without decals and without any metal beyond the entrance flaps. There are I think 16 pieces in total that the whole set that need to be riveted to the new ramp. If I were to provide these 16 pieces, I suspect the cost overall would increase $150-$175, so I promote reusing your existing metal.
All pieces are pre-drilled for the metal that must be transferred. Odin noted that on the prototype Big ramp, one of the optic sensors was mounted down near the entrance to the ramp vs at the upper left corner. I am reproducing the ramp as if that sensor is in the upper left corner. If you have a Prototype Big ramp that has this optic sensor down near the entrance and want to preserve it, let me know and I will send you a Big ramp without the pre-drilling at the upper left corner. You would need to position your sensor on the ramp then mark and drill the mounting holes for the bracket and the two 1/4" holes in the side of the ramp.
I am also not providing decals and I was easily able to remove my own. They cleaned up beautifully and I will reuse them. As soon as I take a break from ramp making, I will assemble my own set of ramps and post pics. If you want a new set of NOS Dredd Decals, there are some available to purchase at Pinball Inc. Note that as I write this they only have 12 left in stock.
https://www.pinballinc.com/index.php?route=product/product&path=120&product_id=292
Prices:
Big ramp $235
Stakeout ramp $125 (Includes ball containment piece at the top of the ramp)
Air Raid ramp $65
Black Out Ramp $130
Functional Subway $65
2 Piece Dead World Subway $115 (This is a non functional subway.
There is a full set discount of $35
For those interested, JodyG here on Pinside (aka rampomatic.com) has hand held rivet kits for sale.
Also check out his tutorials for both riveting and reusing decals!
Sun came out today so took outside photos.
IMG_1879 (resized).JPGIMG_1880 (resized).JPGIMG_1881 (resized).JPGIMG_1882 (resized).JPGIMG_1883 (resized).JPGIMG_1884 (resized).JPGIMG_1885 (resized).JPG
