Interested! Can you please add me to the list?
Im trying real hard here to get a tron, theyre kind of hard to find for a reasonable price. If i have mine you can sign me up for sure!
Control board for the fiber optics as well? So just one system that is able to control both ?
Quoted from Pastor69:Im trying real hard here to get a tron, theyre kind of hard to find for a reasonable price. If i have mine you can sign me up for sure!
That's the primary intent actually.
But just to be clear: 1/ I can't control Eli fiber emitters, I don't have access to the schematics and 2/ it's unlikely to be at the level of flexibility that Eli solution proposes, I'm not sufficiently proficient in SW development. But at least it will be documented.
I am just seeing this mod and am very interested, please add me to the list for disc mod if you have any open slots.
Quoted from Ashram56:That's the primary intent actually.
That’s cool. As long as you are able to update the code with a USB its perfect.
Please add me to the list! So cool that Tron mods are getting some love again! I thought they died off when I finally got my hands on one.
I'm still alive !!
Professional activity and personal life always have a tendency to get in the way of pinball
Anyway, I have received the HW prototypes. I have some mixed results, fighting with the SW side, I might have to spin the board to fix some assumptions I had made which proved to be inaccurate.
With regards to the disc:
It is possible to not replace the disc, but it requires to decouple it from the shaft. Coupling is done through a screwed in allen screw, and both of those who tried (me and another pinsider) could simply not unscrew it. In this case, it is pretty much required to remove the center rubber on the disc to access the three main screws. Which means afterward cleaning up the disc to replace the rubber.
This is the occasion to replace all rubber to transparent, but sometimes the glue residue are a pain to remove...
So probably best indeed to plan for a disc replacement and set of transparent rubber as part of the kit.
Rubber replacement can be found in Europe here:
https://www.pinball.center/en/shop/pinball-parts/pinball-rubber/miscellaneous/4365/disc-rubber-set-for-tron-legacy-transparent
or here:
http://pinball-mods.com/oscom/spinning-disk-p-51.html
(although if someone has access to a laser CNC, probably cheap to manufacture yourself as well)
I did order a replacement disc back in the days, but can't find it online right now though
Further progress: SAM bus detector is working.
I can detect all coils/flashers easily. I actually have modified my original mod, which was relying on triggering directly through the motor relays to control the ledring, to now use this SAM detector which sits on the data bus. Neat and elegant.
It also opens the door to other effects, originally I had limited myself to motor on and disc direction, but I could also add effects depending on other coils/flashers (btw, does someone recall if the flasher beneath the disc flashes as long as the disc is spinning, or does it flash only when the disc entrance opto is triggered ?).
Next step: Redesign the board to clean up the design and make it more "manufacturing" friendly (and smaller, current setup interferes a little bit mechanically with the cabling)
After that I can discuss with @PinFandago on how to best setup the manufacturing pipeline for the complete mod.
Inserts will take a little bit more time, from the HW perspective no change, but SW is far more complicated (such as : how to detect a blinking state)
20230403_162241 (resized).jpgQuoted from Ashram56:Further progress: SAM bus detector is working.
Inserts will take a little bit more time, from the HW perspective no change, but SW is far more complicated (such as : how to detect a blinking state)[quoted image]
Looks epic!
What language are you using to detect the coils/flashers etc? If its open source i can look into it and possibly help with the sw side =)
Just as an update: PCB layout for second revision of the protoype board is now complete, fully integrated (which is cool, no soldering required). It takes about three weeks for manufacturing and delivery, after that it's testing time again to ensure I did not break anything.
Quoted from Zitt:If someone can send me an old disc a Tron. I might be able to get just the disc made out of PolyCarbonate.
That is if there is a need / won't come with Ashram56 's kit.
Zitt/John,
Do you mean like these but Molded in Poly Carbonate which would probably be a lot clearer than the Machined Disk on the factory Part [which I think is Acrylic] ?
https://www.pinballlife.com/tron-plastic-spinning-disk.html
TRON_Disk_Plastic (resized).pngGood morning everyone
Life and work have a tendency to get in the way of pinball.
Yes it's still happening, but my second prototype had some failures which I did not have time to diagnose. It was neat though, but could not decode correctly the events for some reason. I'll respin it as time permits.
i'm not really in the mod business, was just doing this in my spare time, so please bear with me
Cheers
I’m going to offer a small run of five units of my variant of this project since I already had extra PCBs from my original minimum quantity order back when I made my personal unit one year ago.
This variant is slightly different in that it will turn the effect off when the GI goes out for a factory integrated look when other factory effects are being done while the GI off.
Anyway, I only have an LE to develop with and have never seen the underside of a Pro model to make sure everything would be a plug-and-play kit. I do know the Pro doesn’t have all the LED lamp boards and that is where my mod gets power from on the LE. I’m also not 100% sure if the disc direction relay assembly connector pinout is the same between the LE and Pro. The manual does show they are, but with only one wire color difference while still having the same pinout for my connector tap that grabs the spin direction signals from. A matter a fact, my LE has the same wire colors as the Pro according the diagram and I think the LE diagram is incorrect. I’m leaning towards they are identical, but it would be nice to get a pic of a Pro owners 6-pin relay connector to verify this assessment. I’ll attach the LE 6-pin connector for someone to compare with.
I have all the parts built and only waiting on making installation instructions. I plan on hopefully having that done by this weekend. These were surprising time consuming to build up and with so much wiring and connector terminations. I still need to add everything up and labor to come up with a price yet.
I’m tempted to only offer this small run of five units to LE owners since everything would be known to be plug-and-play with what I have already built up. If not, I suppose could add another 2-pin molex connector going to the LE power tap PCB. This way the tap PCB could be removed and an optional Pro model cable connection that grabs power from the 4-pin power connector near the service power box inside the cabinet.
20240319_084141 (resized).jpg20240319_092035 (resized).jpg20240319_092127 (resized).jpgI apologize for the lack of update and very slow progress. As I had noted originally, I'm not in the mod business, and I have to balance professional life vs family vs pinball. So I have the boards, but I've had zero time to work on them.
If anyone wants to go ahead with Tekman offer, please do !
I'll still work on the mod when time permits
@Tekman, if you're interested, I can send you one of my prototype board with SAM bus capture. Basically you capture data from the bus instead of triggering on the motor relays.
Quoted from Ashram56:@Tekman, if you're interested, I can send you one of my prototype board with SAM bus capture. Basically you capture data from the bus instead of triggering on the motor relays.
I'm really just interested in offering this small run of five units to utilize the extra PCBs I had leftover and offer a chance for people to have it now. Your SAM bus approach would be great for Pro owners that might be able to also use that to add ramp lighting control or other triggers as well. I think my offering is really best suited for LE owners or Pro owners interested in having the LED ring now. My motor direction triggering is a simple tap on the 6-pin motor relay connection (image attached).
I think I would be more interested in your new design you're working on if I didn't already have an LE, so I'm content with the original concept.
20240319_154542 (resized).jpgAll five kits are built and I'm 75% done with documentation. They will be available on my website this weekend. I don't do wait lists or preorders and they will be first come first served on my website. No price established yet and they will be limited to one kit per person to be fair with such a small run.
Like I stated before, I developed this on an LE to be plug and play. I was really hoping a Pro owner would have chimed in by now when I previously asked if someone could compare their 6-pin motor direction relay connector with the picture I posted. I suspect they are identical, but it sure would be helpful if someone could physically confirm that by this Sunday. If not, I'll probably only offer these to LE owners to play it safe.
https://lundyelectronics.com/shop
20240322_074704 (resized).jpg20240322_151231 (resized).jpgFigure 13 (resized).jpgQuoted from Tekman:Like I stated before, I developed this on an LE to be plug and play. I was really hoping a Pro owner would have chimed in by now when I previously asked if someone could compare their 6-pin motor direction relay connector with the picture I posted. I suspect they are identical, but it sure would be helpful if someone could physically confirm that by this Sunday. If not, I'll probably only offer these to LE owners to play it safe.
I can take some better pics if needed, I believe this was the correct relay?
PXL_20240322_212239544 (resized).jpgPXL_20240322_212301121 (resized).jpgQuoted from Tekman:All five kits are built and I'm 75% done with documentation. They will be available on my website this weekend. I don't do wait lists or preorders and they will be first come first served on my website. No price established yet and they will be limited to one kit per person to be fair with such a small run.
https://lundyelectronics.com/shop[quoted image][quoted image][quoted image]
I like to reserve one please, my LE needs this
Quoted from animesuperj:I can take some better pics if needed, I believe this was the correct relay?
Yes. The Pro and LE appear to be identical. Thank you for helping out.
My TRON Spinning Disc LED Effect Mod Kits were made available on my website yesterday afternoon. I still have two left this morning for those that didn't notice.
https://lundyelectronics.com/product-category/pinball
Instructions are here to see if this is something you feel comfortable doing first before you decide.
https://lundyelectronics.com/shared-files/952
Quoted from Tekman:My TRON Spinning Disc LED Effect Mod Kits were made available on my website yesterday afternoon. I still have two left this morning for those that didn't notice.
Just ordered the last kit, I think. Thanks for supplying the instructions, not as bad as I thought.
Thank you, everyone. These SOLD OUT pretty fast and I look forward to seeing them in action.
We owe Ashram56 a BIG thank you for making this idea possible!
Quoted from evileye:Just ordered the last kit, I think. Thanks for supplying the instructions, not as bad as I thought.
You did get the last kit. The install process is pretty straight forward as long as you take your time and thoroughly follow each step.
Quoted from henning:Dang! Oh nooo, I missed it… But congrats to everyone who got one.
Me too, can’t believe it! Been waiting and watching for 2 years only to miss this opportunity because I was not on pinside for a few days. If anyone changes your mind and wants to sell please contact me.
Quoted from Pin_-_K:Zitt/John,
https://www.pinballlife.com/tron-plastic-spinning-disk.html[quoted image]
Yes. Sorry, missed the update.
I went ahead and ordered more LED rings and PCBs yesterday and will make another run of these again.
I gave this some thought and this will get this mod to people sooner than later while Asram56 works on his new design with SAM bus connectivity.
Ashram56 It would be great if you used my same LED ring connector pinout in your new design, so anyone that wants to change from my hardware design to your new design in development would only need to make a simple connection swap to the new board. Since all the hard work of the LED ring installation would already have been completed, it would make for an easy transition.
I should have more kits showing up in stock in as little as a couple weeks if deliveries from China go as planned.
This page was printed from https://pinside.com/pinball/forum/topic/tron-disc-mod-open-source/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
