Quoted from Flynnyfalcon:So I removed the audio cable from the MPU.
Pin didn’t boot, heard what I assume is the relay clicking from solenoid driver board
Turned it off
Then it booted
Game started and played
Played a ball then all coils stopped working other than flippers
A few seconds later, smoke started seeping out from below the playfield. Yikes!!!Opened the coin door and smoke flowed out, shone the torch in but couldn’t see anything. Quicksilver is kinda jammed in the corner of my shed, so I was unable to open her up. I pulled the cables out of the Rectifier Board for safety. Quickly moved a few pins out the way and was finally able to pull the glass and lift the platform. Nothing obviously burnt in the cab or playfield. Rectifier fuses all buzz out, under playfield fuse buzzes out. Flipper coils measure at 4ohm. All other coils measure from 13-30ohm. Couldn't fins anything... Was almost going to turn it back on to see if I could track down the burning/short/etc... but thought better of it.
Did you check & test the Knocker coil Chris? and also the coin door lockout coil if connected. If the Knocker coil locks on it will smoke as it's not fused (via the 1 amp playfield fuse) also the coin lockout if that's shorted as that's not fused as well & can burn before the 7A F4 blows.
