Quoted from newovad:Getting just GUARD gets you the jiggle on the end. Getting 4 of 5 shots in the hurry up mode gets you the whole line.
It's solved!
It's solved!
Quoted from HiRez00:AKPhill
Where did you get your Baywatch Cliffys?
I can’t seem to find them in stock anywhere.
Thanks.
I got them from this site.
https://www.rtbb.com.au/product/baywatch-4-piece-protector-set/
At the time there were two sets in stock, now they are out. It’s possible they actually only had one set left and I got it.
Can someone take a picture of how the little metal bracket attaches to the end of the VUK ramp.
Someone did a botch job repairing the one on mine but I need a decent photo to see where the metal bracket / foot attaches to the ramp in order to fix it properly.
Thank you in advance.
Quoted from HiRez00:Can someone take a picture of how the little metal bracket attaches to the end of the VUK ramp.
Is this what you are looking for…sorry the dolphin is a little in the way. He is there to protect the often broken plastic.
-Lb
Is there an “accessory” plug like on stern Whitestar systems?
Is there a place I can tap a constant 12vdc for when the machine is turned on?
I have some special mods that need a constant 12vdc.
Thanks.
Can you measure the length of the vertical per of the bracket at the end of the VUK ramp. From the base to the top of the vertical piece that is welded to the ramp.
It seems that whoever did the crummy fix on mine bent the vertical and I can’t straighten it back out without it looking like crap.
I need to reproduce the whole bracket that secures the ramp in place (ie: where your dolphin is) and weld it to the ramp.
Quoted from HiRez00:SirMachismo
The area is a little tight, hopefully this will help. The two marks represent aprox. from the top of the support to the top & the bottom of the support to the top. Soooooo, 7/8” on center is my best approximation.
IMG_4745 (resized).jpegIMG_4744 (resized).jpegIMG_4749 (resized).jpegThat’s perfect. Thank you for taking the time to do that for me.
Will post photos of my repair once I am done. I plan on having all the ramp / rails resurfaced and powder coated to look brand new.
Thanks again.
P.S. you have any idea where to pull steady 12vdc power for when the machine is turned on? I was hoping the machine had an accessory plug like in sterns from 2000-2014, but it turns out there isn’t.
I have a mod I am working on that needs 12v consistently.
Thanks again.
Nice, looking forward to see your finished product. I love this pin so much. I used the service plug near the coin door, a kasa smart plug (with my Alexa) and this adaptor when I installed flipper fans.
I also recently installed a mirror & art blade combo on my BW.
IMG_4759 (resized).jpegIMG_4653 (resized).jpegIMG_4649 (resized).jpegIMG_4651 (resized).jpegIMG_4652 (resized).jpegQuoted from RyanStl:It's solved!
Nope. Guess I should have taken the glass off. I got this response in my Pinside mail.
You need to score 100M in the mode to get the whole line of girls jiggling. Only need to quickly hit 3 jackpots before the value counts down too low. If you are too slow in hitting the jackpots and they count down too far, even four or five won't do it if your jackpots don't add up to 100M or more.
Where’s the best place to source cabinet decals? I picked up a Baywatch and the cabinet is in rough condition.
Anyone have experience with Retro Refurbs Baywatch decals?
Quoted from Tres:Where’s the best place to source cabinet decals? I picked up a Baywatch and the cabinet is in rough condition.
I went with Retro Refurbs as was pretty happy with the result. Note the tops of the girls heads on the side art will get a little more cut off than the originals
The bracket is 1" long x 15/16 high x 7/16 wide. These are all external measurements so if you had a small box with internal dimensions these sizes it would fit in exactly. The metal is the same diameter as the u shaped piece that loops down at the front of the wireform, just above the bracket.
20240416_080137 (resized).jpg20240416_080229 (resized).jpg20240416_080456 (resized).jpgQuoted from HiRez00:SirMachismo
Thanks again.
Or if you want to buy the wireform in the photograph its your for £50 shipped and it will take about 10 days to get to you from here in the UK. It has light corrosion worst being at the rear where the VUK is (see macro pics) Paypal F&F.
Plus I have loads of other spares for Baywatch and it shouldn't much if anything to the to the postage to add another lb or so.
Paul
20240416_080305 (resized).jpg20240416_080325 (resized).jpg20240416_080341 (resized).jpgSo I’ve been properly shopping my Baywatch pin. When I dismantled everything off the playfield to clean it, there were some things that seemed a little “off”. I think whoever shopped it before me didn’t use the original screws and parts and used whatever they had laying around their place. There were 22 different screw and nut sizes that took forever to remove because it seemed I need a different tool for each piece.
I have attached severa photos of the cleaned off playfield.
Can some upload photos with similar angles that show how certain pieces attach and the proper screw or bolt sizes. I can figure out the proper bolt / screw / nut size, I just need some reference photos to work from.
Like I said, I think whoever previously worked on this machine reassembled it wrong because there are a bunch of warped plastics and things that just don’t seem to fit together properly with the hardware that was on the machine when I got it.
IMG_2286 (resized).jpegIMG_2287 (resized).jpegIMG_2288 (resized).jpegIMG_2290 (resized).jpegQuoted from HiRez00:AKPhill
Please send the link as to where to order those protectors!
Thank you.
Sadly they are out of stock at this time. No idea if and/or when they will get another set in. You might have to get them from Cliff himself, and that will take some time since he’s backlogged.
Thanks for the info. I will try messaging both rttb and cliffy to ask to be put on a waiting list if possible.
On a side note: I made a bracket for my new shark toy and got it mounted this morning. Also have a coast guard chopper with lights and spinning main rotor, a scuba diver and an octopus to mount today as well.
IMG_2291 (resized).jpegQuoted from HiRez00:AKPhill
On a side note: I made a bracket for my new shark toy and got it mounted this morning. Also have a coast guard chopper with lights and spinning main rotor, a scuba diver and an octopus to mount today as well. [quoted image]
For Cliff you email him your order. Unless he already has a BW set it could be many months to get because he is severely backlogged. I put Cliffys on mine and one protector did require adjustment. I believe info is in this thread.
Shark looks great - just a shame it hides the sign but I guess that’s where it fits.
This page was printed from https://pinside.com/pinball/forum/topic/baywatch-clubmembers-only/page/103 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
