Quoted from StonecutterJeff:I knew this was the pinball I needed. And I reserved mine and I’m at #52. This is my first pinball machine and I check this thread a few times a day and love hearing all the positive talk. Just a question and thank you in advance to the people who answer this. When this arrives what will I need to do to get this ready to play? I see a lot of tilt needs to be adjusted or it was a slow ball the game needs to be looked at. When the box arrives what will I need to do?
Quick first pinball machine check list:
1. Inspect the box before signing anything from the delivery driver. You might need to inspect further or refuse shipment if the box looks damaged or the tip & tell has blue above the line.
2. Getting the game move to where you want it is pretty easy with a dolly and 2 people or very hard solo… especially is stairs are involved. I personally offer cash to the delivery driver to help me get it into my basement and they always say yes.
3. Once in the room you want it, you have to bolt the legs on which is again easy with someone helping. If not you need something easy duty to prop one end up with. (I use an industrial stool)
4. Flip the back box up and make sure the it’s latched it the back (so it doesn’t crash back down into the glass)
5. Open the coin door with the keys and unlatch the lockdown bar. Just inside the the coin door there is a latch on each side. Pull the lockdown bar up and off. Slide the glass down and off the game. Set ball on the playfield to “install”. (You will want to change balls every few hundred plays or so to avoid playfield scratching/damage)
6. Level game: Use a digital level on the playfield to pitch the game. This varies by game and personal preference but 6.5 degrees is common. Usually the front legs are screwed all the way in and the back legs are extended to get the desired pitch. Also make sure the game is level side to side.
7. Optionals: Install the tilt bob (usually on the left side inside the coin box. ( I don’t install on my machines). I like to wax my playfield with carnauba before playing at a bit of added protection but many don’t. Some people also put mylar on areas of the playfield that take heavy abuse. I personally will be adding a “Mylar Magnet Protector” (https://www.pinballlife.com/mylar-magnet-protector.html)
8. Slide the glass back up and latch the lockdown bar back down. Close the coin door. Flip the on switch (under the cabinet on the right)
9. Hit the start button and have fun.
10. Contact Spooky if you have any issues. They have great support. Part of the hobby is tweaking and fixing things over time. Many enjoy this side of of owning pinball machines, like people who tinker with old cars. If you don’t… it can be expensive paying an hourly rate for local house calls. The TCM owners thread will be a great source for help.
“slow ball” shouldn’t be an issue at home. Flipper power can get weak with extended play times (like a pinball show) but gets back to full power when they cool back down.
Well, that ended up being longer than I thought. Hopefully I didn’t miss anything.
