Just picked up a WoZ and it's having an intermittent kickout problem.. from the trough, I guess is how I'd describe it. If I look in there I can see it kicking a ball but it doesn't have enough momentum to get in the shooter lane. After a few attempts it is able to load a ball, sometimes it works fine. I am assuming it's a problem with the coil, maybe needs a new sleeve but before I go replacing stuff I thought I'd ask.
Btw, is the only way to source parts like even a shooter sleeve through JJ or is there a way to figure out what part is generic enough to work? I have some sleeves here that I can try and match up and I need to peruse the manual to see what data they give on parts. I saw the coils were labeled with JJ part numbers so I assume it's going to be hard to find those part numbers at any retailer (Marco had very little for WoZ for example).
