(Topic ID: 275994)
System 11b resetting low 12v
By Bax1
#1 3 years ago
Have a cyclone that was having random resets. Recapped power supply and has been good for a month. Last couple days it has been resetting during random times. hit the pops (reset), hit the drop target (reset), hits Ferris wheel switch (resets). +5 and -12 is good just 12v is low when plugged in to mpu. Unplugged +12 is good. Any advice to start checking is appreciated
#2 3 years ago
Are you testing the voltages on the power supply test points? Or also on the mpu. I ask as i’ve seen instances where crappy connections rob you of good voltages on the PS leading to borderline at the mpu.
Replacing the caps would off forced you to unplug the connectors and replug them in again after. Maybe this cleaned up the connections temporarily but now they are oxidizing again. Just a thought.
#3 3 years ago
Testing off of the test points on power supply. Also testing 5v on mpu and at the connector for 12v. Also 12v on the connector on sound board when all plugged in 12v goes down to 9.25v when power to mpu is unplugged goes up to 12.3v. Would low 12v cause resets?
#4 3 years ago
so if I am reading the schematics correctly, the +12 is the reset circuit? some caps and diodes in there and also tied to u51? could any of this cause the drop in +12v?
#5 3 years ago
Quoted from Bax1:
You can pull the 12v connector pin off the MPU and see where the voltage reads but I doubt the reset circuit of the MPU is causing the 12v to drop out. Its probably the large 5v load of the MPU making the 12v dip.
How are the power supply board connectors and fuse clips? Can look for excessive voltage drop happening across fuse clips, connectors, bridge, etc. Ground input plug 3J2 on PS has been known to burn up.
#6 3 years ago
If you have any mods that are tapped into the 12VDC check those too.
#7 3 years ago
So when I pull 3j6 from the power supply, it will go back to 12v. Only thing I can think of that may use 12 v is the ferris wheel. I get 4.98v on the 5v test point on the mpu. how could I tell if I have a large 5v load? Power supply connectors are ok. 3j1 has a hack on it but it is a working hack. pins 10,11,12 are soldered in wire to a 3 pin connector. I don't see a 3j2 in the schematics on the power supply
#8 3 years ago
any ideas? should I pull the 12v from mpu and then sound board to see which one might be pulling it down?
#9 3 years ago
I've personally never had this problem on the Sys 11 games I've owned but this bit from http://techniek.flipperwinkel.nl/wms11/index2.htm#reset may be applicable:
Low +12 volts from the Power Supply board.
If your +12 volts is low (below 10.5 volts), check/replace the large power transistor 2N6057 on the power supply board. Sometimes the socket used to connect this transistor is corroded or simply not making good contact.
#10 3 years ago
I saw that and did pull it to test. didn't test blown but I may not be testing it correctly.
#11 3 years ago
good write up from who ever did that. I didn't see this section. Is the 12v any of these parts?
The POR section's job is to look at the +5 and +12 volts, and make sure they have stablized, as determined by zener diodes ZR1 (1N5996A, 6.8 volts .5 watt) and ZR2 (1N5990, 3.9 volts .5 watt) before starting the CPU. This is done by transistors Q34, Q36 and Q38, but before these three transistors can work, capacitor C30 and resistors R55 and R56 provide a delay to allow the voltage to stabilize. Only then the /RESET line can be released.
#12 3 years ago
Quoted from Bax1:
It's a bootleg copy of the cfh guides that he took down several years ago.
#13 3 years ago
Ok what did I do? Changed the socket and transistor at q5. Now have +12 and -12 but now my 5v is gone?
#14 3 years ago
Morning bump. Any system 11 gurus out there?
#15 3 years ago
Quoted from Bax1:
BR1 on power supply board tests good and neither F5 or F6 are blown?
#16 3 years ago
br1 test good and fuses are good. had 5v before I changed q5
#17 3 years ago
just pulled board and br1 reads .4xx both ways so this is good correct? F5&6 are good
#18 3 years ago
Quoted from Bax1:
Sorry, yes if you have the 12VDC at TP3 those should be good.
Check voltages at all the listed voltages / test points in this schematic. Does the new Q5 test good out of circuit, use continuity checks to be sure you didn't pull any traces or through-holes, check that you installed the replacement in the proper orientation.
#19 3 years ago
test pt 1 -.3
test pt 3 12.2v
test pt 4 -13.8v
q5 is brand new and test good. I also replaced the socket so it has good connection. I did test the 100v and -100v and that is good too. just somehow I knocked out the +5v
#20 3 years ago
3 and 4 are good.
Are C7 and C8 originals?
Measure voltages at pins 11 and 5 of IC1.
#21 3 years ago
I've not had to troubleshoot that circuit much except for a weak transistor but in your case I believe it has to be a bad Q5 or the regulator (comparator) or an associated component is bad, trace broken etc. Since it was working, albeit poorly, before I question Q5 first and foremost. Check the voltages at all the connections (EBC) to Q5. As you can see C should = TP3 so 12.2V in your case (a little low), B should = ~6.5V. Also check voltages at pins 5, 6, 12/11 on the IC.
#22 3 years ago
will put the board back in after work. Only have about an hour to go and then will run those checks. Thank you both for direction.
#23 3 years ago
Quoted from G-P-E:
3 and 4 are good.
All electrolytic caps have been changed in July. Pin 5 is 5.3v pin 11 is 23.9
Quoted from bobukcat:
How do I get to test q5? Blocked by heat sink. Pin 6 is 7.2 and pin 12 is 24.1
I have the other q5 will try swapping them
#24 3 years ago
Got 5v back. I think I installed q5 backwards. My 12v is now 10.88 So is the new q5 toast?
#25 3 years ago
So the new q5 still reads .5 with neg lead on cap and pos on each leg. Each leg is reading .5
#26 3 years ago
Quoted from Bax1:
That's a darlington pair transistor, NPN so put the red leg on the base and the black on the emitter and you should have about 1.2 - 1.4 voltage drop, maybe a little less. Other direction should test very high or open. Since you have your original voltages back I agree you have a bad transistor or you installed it wrong and may have blown it up. Again it's a been a while since I worked on that supply in a Sys 11 but I'm trying to help, maybe GRUMPY or one of the other Sys 11 gurus will chime in. Ed from G-P-E (apologies if it's not actually Ed) has a good question about the two caps but I'm assuming you replaced C7 and C8 when you say you re-capped the supply?
Edit: Testing these types of transistors is a little different and can confuse people not used to them because, as you can see in the schematic it is one package containing two transistors, a diode and two resistors (to bias the second transistor). The pin out should match the attached drawing.
#27 3 years ago
My mistake. When testing the transistor I was in ohms. With the power supply in the game, I don’t see how to test the voltage. Only played one game and no reset but still want to get the 12v right. How was the voltage for ic1?
#28 3 years ago
So how do you test q5 out of socket. Would like to see if I blew the new one. Kind of crazy that putting it in backwards gave me my 12v back
#29 3 years ago
Out of circuit put your meter on diode test and test as bobukcat described above.
#30 3 years ago
Ok put red on base black on emitter and get .6 If I reverse I get 1.038 so probably blown huh
#31 3 years ago
Sounds like it. Check the other ways too. This is what I get: red collector and black base = no reading; black collector and red base = 0.544; Red emitter and black collector = 0.452; black emitter and red collector = no reading; red emitter and black base = no reading; black emitter and red base = 0.565
I think I got those right.
#32 3 years ago
cool thank you. I will do some testing. I did go pick up another one just in case. I also put in the old one and played a few games last night with no resets. Still want to get the 12v right though.
#33 3 years ago
So good news. Doesn’t seem installing backwards blew it. I had very similar reading on mine as well on the new one I picked up on Thursday. Now just need to swap them and see if it’ll correct the 12v
3 years later
#34 6 months ago
I’ve got a couple games suffering from this issue. Very intermittent. New caps on power supply were no help. Replaced the 2n6057 on Pinbot and it seems better but not perfect. On both I only see voltage drop while sound board is powered. New BR on Cyclone seemed to help but not enough. It can go a couple of days without trouble, then it can’t make it through five minutes.
I pulled the 6057 on Cyclone, sanded the contacts, applied deoxit to the socket, and mated the connection several times. I did observe corrosion on the 6057 contacts. The old 6057 measures .4 and .6V, same as a new one. Putting it back together the reset issue was much worse.
Theory is the 2n6057 socket is causing the trouble. Maybe all that effort turned a questionable socket into a bad one. Thinking of just soldering the 6057 in directly. Is there a better appproach?
#35 6 months ago
Are you certain the replacement 2N6057 are legit? It's super common to run into fakes/knock-offs apparently. I would more readily assume that to be the case than a bad socket.
Post a couple close-ups of the replacements, it may help someone spot whether they're legit or not...
Edit: it's possible I'm thinking of a different one, the LM323K which looks similar to this in shape/package but is a different type of component. I'd still try to verify that what you have is a legit part though...
#36 6 months ago
Thanks for the answer. The 2n6057 I put in Pinbot came from Marco and has the right markings. The one I pulled out of Pinbot tested good, making me wonder if I replaced it for no reason. The one I pulled out of Cyclone also tested good so I put it back, and the reset issues were a million percent worse after futzing with the socket. That’s why I’m thinking maybe socket
#37 6 months ago
Quoted from spblat:
Marco doesn't have a monopoly on non-counterfeit parts. They're subject to the market just like everyone else is.... someone just got remarked 2732's from them, and others have gotten bad parts as well.
#38 6 months ago
Well here’s where I am. TP3 used to wander around between 8.5V and 10.5V, which is how we get intermittent resets. This was known back in the 80s—there’s even a note about it in the schematic.
I replaced nearby caps and the 12V bridge rectifier. None of the parts I pulled tested bad. I saw a momentary improvement that was probably wishful thinking. I saw another forum post about diodes in this regulator circuit. Despite the fact that D1, D5 and D6 seemed ok in circuit I replaced them. Out of circuit they test good.
Now TP3 is a volt or so higher than it was and seems stable at around 10.5V. My only working theory is that the bridge rectifier and/or those diodes were on their way to failure, even though they tested OK. It is known that a component might behave differently under load than when examined by a multimeter but I just have no idea.
Here’s a few pics with captions—
replacement part from Marco. Seems to behave the same as the part I pulled.replacement part from Marco. Seems to behave the same as the part I pulled.
TP3 over 15 minutes. The two blue lines are where it was before replacing D1, D5, D6.TP3 over 15 minutes. The two blue lines are where it was before replacing D1, D5, D6.
I couldn’t find a diagram that legibly identifies the components in the board. Here’s what I traced out.I couldn’t find a diagram that legibly identifies the components in the board. Here’s what I traced out.
#39 6 months ago
Schematics show this as a simple series pass transistor type regulator. Too low of input voltage and the regulator circuit will 'drop out' resulting in glitches or drops in regulated output voltage. Too high of input voltage and the regulator circuit has to dissipate the excess input voltage as heat. Sweet spot for this circuit is near the 12V value but varies depending on your specific 2N6057.
2N6057 is LONG obsolete. Those in the photo would be pretty old stock. For awhile, 2N6059 was the manufacturer recommended replacement part.
As of about 5 or 6 years go, 2N6059 also went obsolete.
Recommended replacement is now 2N6284. You can find these at Mouser -- search for 2N6284G.
Sockets for TO-3 transistors are horrible and have had them cause all sorts of problems in the past.
Not a bad idea to replace socket. Get AMP (TE) part number 8080-1G1-LF which is also available at Mouser.
#40 6 months ago
Thank you! And thanks also for existing, I got a bunch of your stuff in my games over the years
#41 6 months ago
Quoted from spblat:
That 2N6057 looks like a remark. The top of the cap looks like it's been painted silver with the part number printed on it. Genuine parts have the part number printed on metal.
#42 6 months ago
Quoted from Quench:
Well what do you know…
#43 6 months ago
spblat
I have taken the liberty to add your photographs to the PinWiki, here:
https://www.pinwiki.com/wiki/index.php/General#Counterfeit_Integrated_Circuits_.26_Blacktopped_Parts
If you would prefer that I not, please LMK, and I will remove the images.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
https://www.youtube.com/c/ChrisHiblerPinball
#44 6 months ago
Chris --
On your webpage, the two 6821s also have another indication on them that shows them to be fakes.
Right side photo of 6821, date code is "0438" (38th week of 2004). Left side photo of 6821 - Jerry's photo, date code is "0640" (40th week of 2006).
Motorola issued a last time buy for 6800 and 6821s with a date of December 1999. Last time deliveries were in scheduled for 2000 but I was told they stretched into 2001. Absolute latest date code for 6800s and 6821s would be 2001.
Jerry's part may have worked but the date says it was made 6 years after it was discontinued. Definitely a remark. And since it misrepresents the age of the part, it qualifies as a counterfeit.
I still have a bit more info on my website - if you want to, copy what you want from that page because I'm not sure how much longer that will be up.
https://www.greatplainselectronics.com/Information.asp?region=133
My favorite is the photo of a 6810 memory at the bottom of the page with the 40 pin package.
#45 6 months ago
Thanks G-P-E Ed.
Would it be OK to copy that linked page in its entirety into the PinWiki?
I’m going to miss your site.
I still use it to find what I need.
I suppose I’ll always have the wayback machine.
I hope all is well with you and the family and that being unburdened by running GPE is working out for you.
I’m going to send you a PM about another topic you may be able to help with.
Http://chrishiblerpinball.com/contact
Thank you for checking out the PinWiki - http://www.PinWiki.com/
#46 6 months ago
Chris -
Sure, copy what you want from that page.
I have the website paid for another year, I think.
After that, who knows what will happen.
-- Ed
#47 6 months ago
Quoted from G-P-E:
Chris -
-- Ed
Thanks Ed.
#48 5 months ago
Quoted from ChrisHibler:
spblat
I’m honored, thanks Chris. In my particular case there were several red herrings and an obvious solution.
  1. Not the bridge rectifier
  2. Not the regulator—original, counterfeit or otherwise
  3. Not the caps
  4. Not the diodes
Replacing these (yellow circles) did no harm but it would have been better for me to have noticed the heat coming off the AC input connector. It would have been better for me to have noticed the yellow discoloration on that plug. It would have been better for me to have realized that producing all that heat upstream of the 12V regulation circuit makes a perfect hypothesis as to why the PSU could sometimes go a few hours or days between resets.
Next time I’ll see those clues earlier
#49 5 months ago
Toasty
$ 12.50
RoyGBev Pinball
$ 29.99
Daddio's 3D Printed Mods
3,400
San Diego, CA
$ 27.00
$ 36.95
$ 69.00
Pinball Pimp
$ 39.99
$ 19.99
3,800 (Firm)
Auburn, MA
$ 44.99
Pinball Shark
$ 2.50
$ 11.95
$ 18.95
$ 170.00
Displays
Digipinball Shop
$ 69.00
Pinball Pimp
3,650
Copley, OH
This page was printed from https://pinside.com/pinball/forum/topic/system-11b-resetting-low-12v- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
