I recently picked up a Flash, and after digging around found the Div10 flipper ROMs, but thought it looked stupid to be scoring points one at a time.
I've also seen pretty in-depth projects to make Firepower use a System 7/9 display set, which requires all new ROMs, and the new set of displays.
What I'm currently working on is a replacement Sys 3-6 master display board that'll drive my system 7/9 7 digit displays, but shift the digits left one position and insert a 'fake' zero on unused strobe signals, so that with Div10 romsets will appear to give true 7 digit scoring.
I haven't dug too deeply into the Div10 flipper ROMs to see if the high score tables and match are handled correctly, but it shouldn't take all that much work to fix any other issues that may arise, then port the code mods to earlier flipper ROMs.
(...and of course, I'd also make 6-digit displays for people who just want an LED replacement set without all the code changes...)
I'd expect the prices to work out to be about the same or a little less than the pinscore 3/4/6 displays.
