I'm working on a 1973 Bally Odds & Evens.
I'm fairly inexperienced with EM electrical stuff.
All of the backbox bulbs do not work so I went to check the fuses. I noticed this little hack on this fuse holder where they "sandwiched" a second holder onto one with a broken side.
I'd like to put it back the way it's supposed to be but I'm not sure if everything is wired up from the transformer correctly. Specifically, the open spot at 2. Also according to the diagram, I think the wire coming off of spot 7 is supposed to be on spot 5. Does that matter?
I'm not even sure if this fuse is the cause of the dead back box lights - I plan to run a jumper wire later today. If they all light up, I'll be tempted to replace the holder and leave it at that. But, like I said, I'd rather put everything back the way it's supposed to be.
