Quoted from PanzerKraken:Outside of 10mil for hitting all three, I don't think they do anything else.
Found some rules online
A46AECBE-1E45-451B-A81C-8002ADA36837 (resized).jpegQuoted from PanzerKraken:Outside of 10mil for hitting all three, I don't think they do anything else.
A46AECBE-1E45-451B-A81C-8002ADA36837 (resized).jpegHmmm I've never seen those awards for the drop, every time i've taken all three down I would see 10mil appear on screen as the award. Perhaps the other options only work when in nightmare, cause otherwise whats the point of more power if your not in the nightmare?
Anyone replace their plastic ramp when the repros were available and are sitting on an old one? or know who reproduced them?
I have one that looks like someone tried to clean it with with acetone or something and its super cloudy looking. Just looking for something a little better.
Let me know if you can help! Thanks
Quoted from TheCreature:Amazing! Can you show us your whole updated playfield?
Does any one have an STL(s) file for the glove blades? The one on Cults3D doesn't seem to be scaled correctly when it's brought into Slicer.
Quoted from JakeJones07:Does any one have an STL(s) file for the glove blades? The one on Cults3D doesn't seem to be scaled correctly when it's brought into Slicer.
Shot you a PM...call if you like...short answer...his stl is correct...but just like you found - you have to scale...~393%...I think I did 390%, this is simply due to the math 100mm =3.93 inches...I corresponded with him - as I believe you saw - but he simply didn't understand I guess....he initially had an obj that didn't work - I got him to make that stl...just scale it....you are looking for ~3mm of thickness and the center blade to be ~88mm long - that's when you've got the scale correct...that's all I did...the results were perfect...doing the restoration is tricky...takes a long time...but my restored glove(s) has been played quite a bit over 4 months and holding up great....
Quoted from Sonic:Shot you a PM...call if you like...short answer...his stl is correct...but just like you found - you have to scale...~393%...I think I did 390%, this is simply due to the math 100mm =3.93 inches...I corresponded with him - as I believe you saw - but he simply didn't understand I guess....he initially had an obj that didn't work - I got him to make that stl...just scale it....you are looking for ~3mm of thickness and the center blade to be ~88mm long - that's when you've got the scale correct...that's all I did...the results were perfect...doing the restoration is tricky...takes a long time...but my restored glove(s) has been played quite a bit over 4 months and holding up great....
Just saw your message. This response is great, I’ll scale off the 3mm blade thickness!
Thanks so much for your help!
Quoted from JakeJones07:Just saw your message. This response is great, I’ll scale off the 3mm blade thickness!
If you want help on techniques and glues to use - it's a multi-adhesive approach - the tutorials I found were nonsense....they left you with a rather poor looking repair...
Just call
Matt
This is my file and it prints just fine using Cura. I'll have another look at it today.
I checked the file in Cura and it seems fine. Make sure autoscalling is enabled. I even rexported another file and posted it called scaled. Not sure if that helps. I also put the dimensions in case there is any issue. I think you have autoscaling turned off, 30 downloads and I haven't heard anything? Hope this helps.
Quoted from Viggin900:I checked the file in Cura and it seems fine. Make sure autoscalling is enabled. I even rexported another file and posted it called scaled. Not sure if that helps. I also put the dimensions in case there is any issue. I think you have autoscaling turned off, 30 downloads and I haven't heard anything? Hope this helps.
Can you go ahead and post the link to the scaled file again just in case.. I didn't find it .. I'm using prusa.... It didn't auto scale....
Quoted from Sonic:Can you go ahead and post the link to the scaled file again just in case.. I didn't find it .. I'm using prusa.... It didn't auto scale....
It was added to the project. Sounds like it is Prusa users having the issue?
https://cults3d.com/en/3d-model/game/freddy-krueger-pinball-glove-replacement-blades
Quoted from Viggin900:It was added to the project. Sounds like it is Prusa users having the issue?
Possibly? I'm not sure what JakeJones07 is using - he's never said...
Quoted from Sonic:Possibly? I'm not sure what JakeJones07 is using - he's never said...
Bambu
Quoted from Lowaek:I am looking for a set of the speaker grills/inserts. Does anyone know where I can get a pair? Thanks!
I have a pair at my shop
Anyone looking for the grave walker Freddy for a topper, I have one that I'm selling for 250 that I can bring to the Allentown show. I'll be there Thurs - Sat. PM me if interested.
Fedora is included.
image0 (resized).jpegimage1 (resized).jpegimage2 (resized).jpegimage3 (resized).jpegimage4 (resized).jpegQuoted from DeathHimself:rave walker Freddy for a topper, I have one that I'm selling for 250 that I can bring to the Allentown show. I'll be there Thurs - Sat. PM me if interested.
Fedora
The Freddy pictured above will be also be for sale at Allentown. Easy-peasy.
Hello everyone! Just picked myself up a Freddy on the weekend and am going through it a bit. When I noticed a few bulbs out, it didn't worry me to much. However, when I got it home I noticed that there was something wrong with the light board that goes to the boiler itself. The Grab Freddy, Jackpot and Fall asleep lights still work, but the "Open" socket on the board is loose and the lines that go to that socket have been pulled up and someone attempted to solder them back together. Needless to say that didn't work. I have done quite a bit of searching but have not found anywhere these boards are sold. Would anyone on here have any idea? Cheers!!
This page was printed from https://pinside.com/pinball/forum/topic/freddy-nightmare-on-elm-street-owners-club/page/24 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
