(Topic ID: 345588)
Broken wood Screws
By BubbaK
7 months ago
  • 22 posts
  • 11 Pinsiders participating
  • Latest reply 5 months ago by Mthomasslo
Screenshot 2023-10-25 at 02-20-56 Remove Stripped Screws with Ease Get Your Screw Extractor Now - Rockler (resized).png
#1 7 months ago
I just started a rehab on a Gottlieb Hurdy Gurdy. Other than being dirty, the playfield is in pretty decent shape. I started the teardown over the weekend and I've had more wood screws break off on this one game than I've had in the last 15 games combined. The screws that have come out don't appear rusted or damaged in any way. I broke 3 screws that were holding the card holder on, another few holding the top arch and one or 2 on the playfield. I removed 2 pop bumper assemblies and broke 4 out of the 6 screws holding the coil brackets to the pf. I'm not really looking forward to taking more of this machine apart, but it needs to be done. Are there any tricks that I'm missing? The next issue is how to fix. I had one other break a few games back, and I used a small plug cutter and filled the hole with a small dowel. There are way too many broken screws to be using that method. I'm thinking dremel with a debur bit and fill with epoxy, then drill new holes?
#2 7 months ago
Toothpicks are your friend.
#3 7 months ago
Toothpicks are great for stripped holes. Not much they are going to do for broken screws.
#4 7 months ago
Quoted from BubbaK:
You can try a slice with a cut-off wheel then a flat screw driver.
#5 7 months ago
Quoted from iamdrunker:
You can try a slice with a cut-off wheel then a flat screw driver.[quoted image]
I can give that a shot, but the blade may be thicker than the remaining screw. I did use this method to get a few screws out with stripped heads. It appears the machine may have been stored awhile in a damp environment. No water damage, but many of the screws have rusted threads and there is a lot of oxidation as well.
#6 7 months ago
https://www.amazon.com/ENGINEER-PZ-58-Extractor-Combination-fasteners/dp/B002L6HJAA
Clear out a little wood so you can get these on it and they will grip it
#7 7 months ago
Quoted from radium:
Have a set, these work great
#8 7 months ago
Thanks guys.. I'll have a look at those pliers. It looks like they may a smaller tip. Not sure if the picture makes them look bigger on the tip. I don't want to remove too much wood since the coil bracket needs to sit flat.
#9 7 months ago
Pick up one of these drill guide blocks and some left hand drill bits. The placement of the block will keep you square and in the center of the broken screw and usually the left hand drill bit will walk the screw out. Mark your bit with some tape as a depth stop so you don't drill too far into the back of the playfield.
https://www.busybeetools.com/products/multi-function-precision-drill-guide.html
#10 7 months ago
This block goes down to 3/32” which may be better.
https://www.busybeetools.com/products/drill-block-plus-milescraft.html
#11 7 months ago
Drill block might work, but I think it would have to be clamped so it doesn't move. I'm going to try a few different methods I think. I just ordered a wood screw extractor to cut a 1/4" plug around the screw. I'm also going to order the pliers listed above. The screws that have snapped were pretty tight. The pliers may be difficult or very time consuming. A few drops of oil on the screw may help to give some lube. I also may try the dremel with a deburring bit.
#12 7 months ago
In the particular case you show of the broken pop bumper bracket screws, I'd remount the pop bumper bracket rotated from its original position to avoid risking damage to the irreplaceable playfield.
#13 7 months ago
https://www.woodcraft.com/products/screw-extractor-1-4
Extract broken shaft, plug with 1/4" wood dowel
124210.1 (resized).jpg124210.1 (resized).jpgScreenshot 2023-10-25 at 02-20-56 Remove Stripped Screws with Ease Get Your Screw Extractor Now - Rockler (resized).pngScreenshot 2023-10-25 at 02-20-56 Remove Stripped Screws with Ease Get Your Screw Extractor Now - Rockler (resized).png
#14 7 months ago
Quoted from vid1900:
[quoted image][quoted image]
I gotta get one of these for the broken off siderail star nails
#15 7 months ago
I ordered the 1/4" one last night. I think this may be the easiest way. I'm going to put a shaft collar on the bit to give a more positive stop so it doesn't go through the PF.
HowardR - I looked at remounting it, but the pop bumper switches will have to be relocated as well. I think that will turn into a bigger project.
#16 6 months ago
I ordered the 1/4" extractor that vid1900 posted. It does the job. While I was waiting for the bit to arrive, I tried the dremel with a burring bit. Made me very nervous as well as a big hole to fill. Not ideal.
I made a guide block to keep the extractor in position so it doesn't walk. As long as its centered over the screw, and the screw is straight, it does a good job. The first hole I did, the screw was in crooked and broke the bit. Luckily they are double ended. I've since done 5 without trouble.
20231030_193415 (resized).jpg20231030_193415 (resized).jpg20231030_194010 (resized).jpg20231030_194010 (resized).jpg20231030_200106 (resized).jpg20231030_200106 (resized).jpgdrill bit (resized).jpgdrill bit (resized).jpg
#17 6 months ago
Since I've been breaking the majority of screws on this game, in afraid to take anything else apart. Tonight I tried something to loosen up the screws. I put my 140w Weller iron on the screw heads and heated until I saw smoke. The screws come right out. Wish I thought of it 10 screws ago..
#18 6 months ago
Quoted from BubbaK:
The screw heats up to the point where it expands a little, pushing the wood out a bit, giving the screw the wiggle room it needs to turn out? Pretty neat tip!
#19 6 months ago
Quoted from leckmeck:
I'm going to try to use the pliers listed above along with the heat to see if I can get the last 6 broken screws out without drilling..
1 month later
#20 5 months ago
Thanks for the tip, @vid1900! These things are lifesavers.
https://pinside.com/pinball/forum/topic/abra-ca-dabra-3/page/2#post-7901114
#21 5 months ago
Saved my ass many times
Glad it worked for you too!
#22 5 months ago
Quoted from pinhead52:
I used one to remove broken side rail "nails" when I did my Wizard, and it worked perfectly. Be sure to drill a pilot hole in the dowel (using the side rail as a guide) before driving in the new nails
This page was printed from https://pinside.com/pinball/forum/topic/broken-wood-screws and we tried optimising it for printing. Some page elements may have been deliberately hidden.
