Hi everyone,
I have a Williams Bride of Pinbot with some Controlled gate issue
before i had problems with the head, but that seems to be resolved thanks to the advice here.
Problem:
The Controlled gate does not switch of. (Solenoid 4)
First i have noticed that the connector under the playfield was disconnected. (maybe by someone before me)
After connecting and starting up, i have noticed the relay switched on and stayed on, so the relay part works.
But, it does not switch of, even in solenoid test, it does not change.
So, i think it must be switched to ground at all times.
According to schematics, Q76 handles the relay.
Could there be some part failing here? could TIP36C be shorted?
I am not a electronics expert but have a base knowledge.
Thanks for the help and tips.
