Quoted from Coolbreeze1:Replaced Q19 & Q41 but bank 5 and knocker still energized. Trying to figure out if the MPU or Driver board is causing this. Does the double flash of the LEDs on the MPU indicate the MPU board is OK?
No, there's no testing of the mpu board that would indicate 100% functional (bally/stern doesn't even do this with the bootup diagnostics - it can test the chips, etc. but it can't test the inputs/outputs of the PIAs, just the registers). If it boots up and runs software it's mostly working, and then you have to test outputs to see if any are stuck (logic probe best for this)
If the game wasn't booting the diagnostic routine wouldn't run anyway when you press the cpu board buttons.
It's not clear yet if your game is booting up, is it? Until it is, you can't depend on any signal being 'correct' as until it boots the PIAs are all in a random state. Remove the solenoid and lamp fuses until you are sure the game is booting if it's not.
