Got a couple tips to share with those who do not have access to a cnc, or a flat bed sander when doing your whitewood...
Powertec makes a 50" locking straight edge that is great for doing routing, cutting, laying out, etc. Easy amazon order, and won't break the bank like mostbstraight guides.
Even works at angles with clamps, or the add on cleats.
Also when doing your inserts, if you'll take a finishing router with a 1/2" straight edge bit (cylindrical with a flat bottom), and set it to flush cut about a 1/16, or 1/32 above your wood.
(Make sure to test on scrap piece) you can slowly take off all the excess plastic on your inserts before sanding to cut down time, and to reduce divots, or low spots using a belt sander causes.
All you'll need is a random orbit sander starting with 80 grit, then a 320 grit to have them smooth as the surface wood in no time.
This cut my sanding time down from 2 afternoons to just about an hour.
