Wanted to share my install of Victors 8-Driver PCB board and how easy it made completing the tie back mod that's super needed for this game. If you didn't know, the "diode tieback" connection to the 8-Driver Board is critical for Star Trek: The Next Generation. Without this "diode tieback", transistors on the 8-Driver board WILL be damaged eventually and the associated coil is likely to become locked on and melt.
more here: https://www.pinwiki.com/wiki/index.php/Star_Trek:_The_Next_Generation#Diode_.22Tie_Back.22_missing_causes_8-Driver_Board_transistor_to_fail
Victor's board is referenced earlier in this thread but the basics are it's a super nice board that makes this tie back seamless and implements the pull down resistor.
Parts needed
1 - 8-Driver PCB board - https://pinside.com/pinball/forum/topic/sttng-owners-club/page/188#post-7663782
2 IDC 3 pin connectors - https://www.marcospecialties.com/pinball-parts/5792-10847-03
2 feet of 22 awg wire, violet - https://www.marcospecialties.com/pinball-parts/CW-30022-7
Here is a shot of the two boards next to each other:
Williams vs Victors board
Removal of the original board is super easy, it's located on the upper right side of the head box, a few plugs that pop off, a ribbon cable, and 4 screws
Original 8-Driver board
The board is mounted to the back panel via 4 standoffs:
One nice thing about the new board is that it's key'd vs straight holes on the Williams board, makes it so you don't have to take the screws all the way out if you need to pull the board, I much prefer this design. Photo installed:
installed
Next I made a cable using the parts I ordered from Marcos, you're going to want to use the header at the top of Victors board to connect pin 3 (J4 is labeled next to it) to J108-1 on the driver board. On the harness this means if you ar key'd the same way, the wires will be the inverse of each other. I used IDC connectors though you could also use molex, I just prefer the ease and matching look to the original harnesses in the game.
Push the wires in...
inserting wire to IDC connector
pigtale harness made
Route the wire using the original wire retention loops
wire routing
and plug into J108
And you're done! If you may notice, half way through I swapped out the rotten dog DMD board with the pin sound unit I had in another machine to match the other pin sound components I had in TNG. I do like the pin sound unit and it has a dedicated power supply for the color DMD screen vs using the driver board.
