Quoted from Falc0nWing:I checked the transistors on the MPU and PPB, all seems good. How can I check without a logic probe if the 7408 ICs above the transistors and the PIA above them is good?
If the output transistor is good, the first thing I'd do is disconnect the CN12 in the bottom lower left corner of the CPU and power up the game. This will probably stop the motors from running on power up, and confirms that your relay contacts aren't stuck.
Then it's a matter of following the signal up the schematic.
Noted arcade and electronics repair school technician Randy Fromm suggests this kind of board repair technique:
Identify the problem. Narrow the problem to a particular area. Get a schematic, and photocopy/enlarge that section of the schematic.
Your schematics are here:
https://www.ipdb.org/files/2358/Data_East_1992_Star_Wars_Schematic_Diagrams_English_Manual_pages_46_69.pdf
PDF page 11 has the section with CN12 and the solenoid drivers you are looking at.
Test a part. For instance the output transistor. It tests good. Highlight it on your schematic. Or it tests bad, replace it and highlight it on your schematic. Test it's connection with CN12. Highlight that wire on your schematic. Test it's connection with RA25. Highlight that wire on your schematic. Test it's connection with SOL Ground. Highlight that on your schematic. Test that RA25 has correct resistance (2.7k) between pin 5 and pin 1 (ground). Highlight it on the schematic.
Keep testing and highlighting, replacing parts you have difficulty testing or bad parts as you go. When the area of the schematic you are looking at is all yellow, you've got the problem fixed.
For 7408's I test by substitution. I clip the old one out, put in a socket, and put a replacement in. It's a bit rare for it to be the 7408's but I have seen them in sockets on a couple of machines, and I've replaced them once or twice myself.
If it's the PIA, I personally would consider this fairly advanced board repair, and because of that I personally would buy a logic probe (I got a Radio Shack one off ebay fairly cheaply) and a 'LEON CHIP' to do advanced board repair. For problems this deep in the board it really helps to have the right tools, and once I started using a logic probe and Leon's chip, my troubleshooting got a LOT better. You could just clip the PIA out, put in a socket, and put a new one in.
Quote: High voltage: the voltage is good coming from the transformer.
Yeah, but the high voltage SECTION of the power supply can have problems with capacitors and circuitry that draws too much power through the fuse.
Problems here can show themselves at the voltages measured at the display power plug, so measure those voltages there and see if they are correct, get your power supply board recapped, and if it still is blowing the fuse, rebuild the HV section.
Keep at it, this stuff isn't particularly easy, but each problem has a solution.
Good luck!
