I'm running into an issue with my Pinbot ramp and am trying to diagnose the problem. It was working fine, then suddenly the ramp would get stuck in the up position at startup. I can hear the mechanism firing, trying to go back down, but seems somehow mechanically stuck (although I've verified that it's not actually stuck; I can manually release the spring latch).
On startup, the ramp goes up like it’s supposed to, but does not go back down when it pushes the ball out to the shooter lane. Instead, it keeps firing (5-6 times) then stops. Similar response if I play through and force the solar value (it tries, but can’t go back down after).
I’ve run the solenoid test several times, both with the ramp up and after I’ve manually released it back down. Both ways, it does not go back down at solenoid 06A.
I’ve gone through a similar previous post (below), and am not sure if the issue possibly stems from my Snubber relays (they're original) or something more mechanical with the mechanism itself. Either way, I'm open to any suggestions. As always, I really appreciate any input from this forum.
https://pinside.com/pinball/forum/topic/pinbot-ramp-up-firing-constantly-at-game-start
