Last November I picked up two barn find Williams Hayburners II machines and a Williams Derby Day head. The pins were stored on their backs so the back plates were beyond repair.
Because these were stored in an out building they required extensive cleaning in the ultrasonic cleaner with Simple Green.
The numbers on the score reels were shot so they were replaced with ones I made with my Cricut.
The horse unit was disassembled, cleaned and the leather washers were brought back to life with neatsfoot oil.
The machines were then put onto the test bench to make sure that they could be repaired before investing more time into the project.
I made new backs and used JB Weld two part wood restoration to rebuild the damaged parts of the cab and head.
The cabs and heads were then sanded, primed, painted white and then speckled with a speckling brush.
The artwork was projected onto card stock and stencils were made.
Green and black Dreatex were airbrushed onto the cab to give the soft edges that the original art had.
Legs were bought and the backglass were scanned, fixed in photoshop and printed on paper to test the reel openings as well as the light masks before sending off to have them printed by GameOnGrafix. Also new tempered glass was ordered because these were missing and the pins use an odd glass size so standard glass would not work.
GameOnGrafix printed a black mask layer as well as a top color layer for me. I’ve used them several times in the past for this.
The apron art was beyond repair so it was remade with Gerbermask and the Cricut with Createx for paint and clear coat shot on top.
The playfields were beyond touch up repair so one was a total repaint and the other only has the original two tone lettering so it was a 95% repaint. The pf’s were depopulated and cleaned.
The pf’s were sanded flat, clear coated and drop filled.
I made svgs of all of the pf colors (white, black, dark green, red, orange, light green and yellow) as well as all of the letter and numbering. Each color was then masked and airbrushed starting with white.
For two color numbers I sprayed the background number color, masked off the key line and then masked off these numbers when the area cooler was sprayed.
The main colors were then masked and sprayed.
Finally all the colors were masked and the main background light green and yellow were sprayed.
Any touchup key lining was then done.
Lastly the the pf’s were clear coated with Spraymax 2k. I found that by using halogen spots I could get the clear coat to cure in about three hours. The data sheet for Spraymax says that it can cure in as short as 30 minutes under IR light so these halogens must have put out a fair bit of IR as well as heat.
Here are some shots of the finished machines.
There you have it, four months of work in one post! I plan on bringing them to the Midwest Gaming Classic in Milwaukee the weekend after next.
