Hi ... I recently purchased an Orbitor 1 ... Working through some issues ...
Current issue > No voice / speech
I noticed in owner's manual > Dip switch 17 turns talking On or Off ... I flipped 17 on and off a few times and still no speech ... Any ideas ?
Other current issue > None of the #44 bulbs under the PF are lighting ... (I don't think they were when I bought it)
I have not changed any bulbs so some may be burned out but sure they are not all burned out ... The fluorescent "tube" light was not lighting and I noticed the black plastic tube type fuse holder was broken ... So I got a new one and just soldered it in ... Was hoping the #44's were on the same fuse > but still no 44's lighting ... All fuses on rectifier board test good ... Only fuse I see under the PF is in the front (and think it for the solenoids...??? ) and it is testing good when I put leads of multimeter on the fuse ends and when I put them on the fuse holder clamps ...
Is there another fuse I didn't see ?
What else could cause this ?
ALSO > there is one "extra" connector in the lower left side of back box (see attached photo)... I looked and do not see any place this could be connected to a board ... Is this the problem?
THANK YOU in advance for any help you can give !!!
