New Game Code ! (Mainly Home Team Feature)
V1.05.0 - July 29th, 2022
- Insider Connected - Home Team
The Home Team features allows Insider Connected players to log in
and play without scanning their QR code.
When the game is registered to a home location and set to Free Play,
Home Team can be enabled via Standard Adjust #51 or from Guided Setup.
Up to 8 players can be added to the Home Team from the Stern Insider
Connected Setup menu.
The Home Team can be shared across all games registered at the game's
location by enabling the Home Team Standard Adjustment on each game.
Players need only be added once to the Home Team. Players can be
later removed from the Home Team, and guests can be temporarily
added to the Home Team.
Find out more about Home Team at http://insider.sternpinball.com.
- Insider Connected - adding Insider Connected ability to start 'Gem Mania" if you are logged in
- Insider Connected - 'Gem Mania' award will take the place of 10M Points award in the computer grid
- Insider Connected - fixed the Disc RPM achievement thresholds to make it possible to achieve these awards
- Insider Connected - fixed an issue where some Achievement names were not matched with the names on server
- Insider Connected - fixed an issue where player names on the UI wouldn't always be correct
- Soul Gem Mode - entering the mode with Mind Gem powered up to Level 2 you will have your "Award All Shots" single Mind Gem use converted to 3 "Award Best Shot" uses
- Gamma Ray - score balancing increased base value from 50K to 100K, spin increment from 5K to 7K, start increment from 25K to 10K
- Thor Multiball - Mjolnir Attack (Letter Jackpot) is now awarded at 2X of what it used to award
- Thor Multiball - change Jackpot Value increase from 5K per disc spin to 24K per disc spin
- Extra Ball - consolation score when an Extra Ball cannot be awarded changed from 10M to 25M
- Game Over - fixed an issue with names displaying incorrectly
- Game Over - added the ability to use flipper to exit Game Over screen
- Attract - fixed a "Replay At" inconsistency with fonts and made compatible with up to 4 replay levels
- Attract - fixed an issue with long pricing string combinations
- Adjustment Changes:
- added "IC GEM MANIA CPU GRID AWARD" default is YES but competition install will override to NO
- changed "TARGET GAME TIME" default to 1:45
- removed "ATTRACT ADD PLAYERS" will always prompt for adding players
- System - Updated to V3.20.0 on OS: V2.6.0
- Updated to nodeboard firmware/protocol v1.00.0
- Correct the replay score boost when Standard Adjustment REPLAY TYPE is set to DYNAMIC.
All REPLAY LEVELS for all players are potentially immediately incremented instead of only replay level 1.
- Correct Standard Adjustment FREE PLAY LIMIT. Previously this adjustment would not be honored
in all circumstances. FREE PLAY LIMIT sets the maximum number of free games which a
player can win during a game. Once the FREE PLAY LIMIT is reached, a player will not receive
a free game from:
a REPLAY level (if REPLAY AWARD is set to CREDIT)
a SPECIAL (if SPECIAL AWARD is set to CREDIT)
Grand Champion/High Score (if HIGH SCORE AWARD is set to CREDIT
a match (if MATCH AWARD is set to CREDIT)
The default setting for FREE PLAY LIMIT is 5 games (per player per game played).
NOTE setting the FREE PLAY LIMIT to a value less than the number of REPLAY LEVELS
will decrease the number of REPLAY levels available.
- Fix redundant sound effect when scanning into Insider Connected in some
instances.
- Added Standard Audit "Total Power On Time". This is a lifetime audit of the
hours, minutes, seconds the machine has been powered on. This lifetime audit
will start accumulating with this update.
- Added the ability to unregister a machine via the Stern Insider Connected menu.
A machine must be unregister from an Insider Connected account prior to being
added to a new account. Hilighting and selecting "Yes, unregister this game."
will unregister the game from your account.
- Stern Insider Connect Setup Screens:
IP, network name, and WiFi signal strength displayed in top corners of display.
- Added Net->About->Events page
This page will display:
The current date and time
The date and time the game was recently powered on
The play count since powered on
The coin count since powered on
The paid credit count since powered on
The service credit count since powered on
The coin door open count since powered on
The tilt count since powered on
The date and time the game was previous powered on
The date and time the game was previous powered off
The lifetime power on count
- Update the factory default value of "ALLOW LEFT+START TO END GAME" to "FREE PLAY ONLY".
- Update Install Competition: set "ALLOW LEFT+START TO END GAME" to "NEVER".
- Added new Standard Adjustment "COIN ACCEPTOR" whose value can be "MECHANICAL" or "ELECTRONIC", and
default value is "MECHANICAL". This adjustment is only available when the Country is set to Italy
and Free Play is set to No.
The coin door for Italy with a MECHANICAL acceptor is configured:
left coin switch: EUR 0.50
center coin switch: EUR 0.10
right coin switch: EUR 0.50
4th coin switch: EUR 0.10
5th coin switch: EUR 0
6th coin switch: EUR 0
The coin door for Italy with a Electronic acceptor is configured:
center coin switch: EUR 1.00
right coin switch: EUR 2.00
4th coin switch: EUR 0.20
- Guided Setup
Added "Coin Acceptor" setting, only available when Country is set to Italy and "Free Play" is No.
Hide "Game Pricing" when "Free Play" is set to Yes.
Add translation strings for some top level selections.
- Fix game reboot issue at power on with coindoor interlock switch in the open position.
- Insider Connected attract mode screen updated to display the location name and green check mark with
Verified Location if the machine is registered to a pro account.
