(Topic ID: 278494)
Night Rider Switch Matrix or Dip Switches?
By Pinfert
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Pinfert
#1 3 years ago
I have a Night Rider SS pinball exhibiting some weird issues. It's a known working MPU and Driver Board from a different game. However, when playing a game or in switch test mode, solenoids fire seemingly at random.
I have replaced every solenoid diode, and tested all switch diodes. I have scoured for anything grounding that shouldn't be. I'm wondering if it could be the dip switches set incorrectly. Does anyone have an image of what they should look like?
Other ideas are appreciated!
#2 3 years ago
When you say a working MPU from another game, are you saying from another Night Rider game? Just wondering if you have the correct game ROM's and jumper settings on the MPU board?
#3 3 years ago
Quoted from JethroP:
I swapped out the ROMs, so those should be the correct ROMs. How do I confirm that the jumpers are correct?
#4 3 years ago
The dip switches have nothing to do with the wrong solenoids firing.
Go into solenoid test. Make note of what fires with each number on the display. Likely you have 2 of the same solenoids firing through the entire sequence which would point to one of the activating lines connector's being bad. That's mpu j4 connector pins 1-4 and solenoid driver board connector J4 pins 3-6.
#5 3 years ago
Quoted from slochar:
Thanks, I'll try this tonight when I get home!
#6 3 years ago
Quoted from Pinfert:
https://www.pinwiki.com/wiki/index.php?title=Bally/Stern
See section 3.20
#7 3 years ago
When you say at random, specifically what does that mean? The game is not being played, or during gameplay?
Random coil firing is typically caused by a bad switch capacitor or a bad earth ground connection to the frame.
#8 3 years ago
Quoted from BigAl56:
In test mode coils 4-7 and 9-10 all fire the right drop target reset coil. Everything else seems to fire correctly.
#9 3 years ago
Pursue the momentary signal lines as I posted you are missing some of the signals or they are being held high or low.
#10 3 years ago
How do I go about testing those? Thanks for your help!
#11 3 years ago
Solder the header pins on the boards. Repin the connections, they are probably tarnished. My Night Rider every single .100 connector had lost their springiness and luster on the pins. Just age.
1 month later
#12 3 years ago
Just getting around to this,but I repinned J4 on the MPU, no changes. I have a new alltek MPU in it. Any other thoughts?
#13 3 years ago
I also repinned solenoid driver J4. Forgot to mention that.
#14 3 years ago
I figured it out. One of the pop bumpers had a loose wire, and once unsoldered it back on, the coils fire correctly!
$ 5.00
Playfield - Plastics
$ 100.00
$ 5.00
$ 18.95
$ 149.95
Allteksystems
$ 69.00
Pinball Pimp
Third Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/night-rider-switch-matrix-or-dip-switches and we tried optimising it for printing. Some page elements may have been deliberately hidden.
