So I took a good look at my Pro last night and tried a few things in order to get the barn to do its full effect when the insert light is on solid. What it seems like, is that (at least on my Pro) when the insert is lit solid after completing barn mode, the light looks to be solid but is actually flickering ever so slightly. This is why the barn will not "twinkle" as if on fire but looks to be lit fully solid, which you can see from my video on the last page. As Robert from Hooked has said, the barn will mimic the insert and this is exactly what it is doing.
Now my real question is for you Pro owners. I havent seen any videos of the barn lit when the insert is fully lit solid after completing barn mod. I am curious if all Pro's will do this flicker thing and never have the barn do its burning effect or if it is just my machine. It seems the Premium/LE models light different and when the insert is lit solid, the barn turns off all together. If anyone can check for this, I would really appreciate it becuase its driving me crazy haha. I thought it might be the bulb but its not...
Also, one other thing to mention. I recently said that I needed to add a Diode to the red wire. After some experimenting, I found that I didnt need this after all but the wiring is slightly different for my machine for some reason. All of the pictures I have seen show the clips connecting to the slot where the wires are located. Mine was slightly different where the red wire clips in the middle just like the other pictures, but the black clip connected to the right of the red wire, where there is no actual wire in the insert connection. Once connected this way, it fixed the issue of having other insert lights stay on on the playfield. Picture below where I had to connect my black wire...
