Quoted from billrz:Outlane 5k and top lit 5k holes both will sometimes only reward 3 and 4K. Also the lit red drop only scores 5k most of the time, but it will sometimes only give you 3 or 4. I can film it , but basically all the 5k awards are sometimes only rewarding 3-4,. I can’t figure it out
5K is scored by pulsing the 1K (L) relay five times. The switch creating the 5 pulses is score motor 1A with red+white and slate+red wires.
you'll need the schematic eventually, but the typical diagram you will find on it is below. See https://pinside.com/pinball/forum/topic/score-motor-schematics-help for some info.
use the diagram to figure out where stack 1 is, then notice the A switches are on the bottom level ... so of course you care about one that is hardest to see/access It's easiest to find stack 1 by seeing where stack 3 is due to 3 being mounted diagonally.
some of the gtb score motors are mounted on a hinge so you can flip it up and see the lower switches more easily.
the normal problem is the 1A switch has arced a lot and you'll need to file the contacts to remove most of the pits and burning. Get the metal contact file for this as it's more aggressive than the flex. You pinch the blades to apply light pressure while filing both contacts at the same time to make sure the contact faces are parallel.
if the contacts are mostly gone, you get the fun of replacing the switch blades/contacts.
it could also be the switch stack is just loose or the blade needs a little tweaking to get good switch closure.
having said all that, the same 1A switch is used for scoring 500 points, so if 500 always works, the 1A switch is probably not the issue and it's more likely the L relay switch that powers the score reel solenoid is marginal. Could also be a switch in the path from 1A to the L relay coil is flaky so L occasionally misses a pulse.
suggest you watch the L relay while scoring 5K points a few times. If the L relay is always evenly pulsing closed 5 times, that points to a different circuit than if the L relay is sometimes missing a closure.
