Thanks for the replies. I’m really excited to get some new ideas on how to troubleshoot. I have been working at this for 4 years and have basically worked myself back to square one…. but with lots of “experience”
The reed switch, home, and loaded switches all seem to be working and adjusted correctly. In diagnostic mode I can see that the cannon registers as loaded as expected. ‘Home’ is active until the X-wing pivots past the loading ramp, and the 3rd switch (Ready?) remains active until the very end the the X-wing pivot. Maybe unrelated, but this is about the spot that the xwing cannon might actually fire.
I can get more specific on diagnostics but here is a general summary of what I have experienced.
In play the ball loads at home mostly reliably. As it pivots I can hit the launch button and nothing happens. I can hit it again a few more times as the xwing continues to pivot and it fires often after the xwing has swung past the ideal cannon fire shot, hitting somewhere between the 3rd and 4th target from the left. Other times it won’t fire at all and eventually auto fires on the second pass.
In diagnostics sometimes the motor will not run after repeated start/stop while testing. The cannon coil fires 100% reliably in diagnostics including when the motor is activated/running. I believe if the problem was a cracked wire, this would not fire consistently.
The part of the motor that spins is a little loose but I’m not confident this is the issue.
There is a little resistance from the reed switch and cannon coil cables that might create some additional force on the motor but in diagnostic mode the motor handles some added resistance just fine. I’ve tried holding onto the cannon while running the motor to see if I could replicate the motor not functioning.
I have replaced the coil and wires leading from it down to the connector under the playfield.
I have replaced the reed switch and adjusted it. I did find that the reed switch was being activated by a nearby gate or some other metal nearby.
I replaced the motor since the original had a slightly loose post(?) but I later realized that the replacement motor had a slightly shorter post and was creating some uneven force between the motor and the X-wing rod. I just reinstalled the old motor again since I wasn’t sure how to make the new motor match the height needed.
I have not replaced the motor control board yet.
It looks like there was maybe some damage or someone replaced a couple of the solenoids. Q17,18, 25, 26 all show a little discoloration or damage. I tested each of them with a multimeter and they all showed similar resistance.
I noticed the neon bulb attached at the connector to the motor relay board would light up occasionally when testing. Then I broke that bulb and had to replace it.
Thanks again for your thoughts.
