Hi, I need help with a system 6 board. I can't find the problem.
I used the Pincoder ROMs for system 346 corresponding to my board.
I tested the "blancking" and it's fine. Also test the IC13 and IC16 ram memories and they also show to be ok.
When performing the IC19 test, it indicates failure.
Keep in mind, I tried the cmos memory (IC19) on another machine and it works perfectly.
In addition, in principle I verified that there was no cut track. so that is ruled out.
Then with the oscilloscope I verified if there was no signal on Data and Address Bus that was stuck high or low.
I also verify that the control signals (CE, Reset, R/W, OD) have signal.
If someone could tell me what other things to check, since I'm missing something.
Thanks in advance.
