Hello everyone. I am new to pinball and I need some help.
I got my 1st (only) pinball about two years ago, brought as not working and looking forward to the challenge. Just getting round to having a go at it this week, (I know), and think I have bitten off more than I can chew.
It's a Recel Torpedo (single player) which seems to be all Gottlieb. I cannot find a schematic anywhere, thought I have the schematics for an Underwater (four player version), which I think is confusing me more than helping, (don't fully understand some of the electrical paths).
All the score reels were jammed as well as the ball unit, credit wheel, bonus unit AS relay and the vari-target. I have followed Clays guide and cleaned everything (relay contacts gently) and lubed contact rivets with very thin layer of Teflon grease and cleaned all playfield parts, also checked coils with DMM and coil on 10s score was burned out, which I repalced.
Now for the big switch on and playfield lights, I press the reset (start) button and score motor keeps turning (as expected 1st time), vari target relay is sticking on and score reels not resetting. Found out one of the100 point relay contacts were on top of plastic actuator and not in slot, moved into slot and three of four score reels reset, 10s wont. All score relay contacts look ok. Manually activated 10s relay and the score reel rotates though slight buzzing coming from somewhere and AS relay armature twitching. I have manually set the 10s score reel to 0 (will this work for the reset sequence?), also put a bit of card in the score motor switch to stop the vari target relay from opperating (vari-target in reset position). Now when I switch on, if I opperate the coin switch the score motor moves to its home position and stops, however when I press the start button the score motor continues to turn, guess something is not ressetting, but what? The bonus unit below playfield (step up/down) does not reset (unless I manually activate relay), is it suposed to? I noticed that if I latch the reset relay with the machine switched on the score motor stops at home position and if I latch it then turn on the game it will unlatch, which is the opposite of what I have seen on the amazing YouTube vid "Gottlieb pinball reset sequence" animation by Steve Fury. Other problem is the credit wheel does not move when coin micro switch activated and no apparent relay to opperate? (have added credits to the wheel manually, though guess until game is reset does not matter). I do not know what the AS relay actually does, what operates it or if part of the reset sequence. There is a space on the relay rail in the bottom of the cabinet for a relay labelled AS coins control with no loose loom wires though there is an empty two rows of six Jones socket nearby.
Sorry for the long post and I will try to summarise.
1) Does anyone have a Torpedo schematic or is it the same as the Underwater schematic, (see ipdb.org) and just ignore players 2-4
2) Am I missing a AS coins control relay and just whistling in the wind without it or is this just for four players (board is generic marked Torpedo and Underwater)
3) Can I eliminate items from the start up sequence to isolate problems
5) Is the bounus unit under the playfied part of the reset even though it is step up/down
4) Any suggestion would be greatly appreciated
Best regards
Mike
