Posting this here to see if I am on the right track as I have never had to work on the switch matrix for an WPC game before.
My Shadow is reporting a Ground Short R1 for Switch 51, Brick Wall drop target down (white-brown wire). The switch is activating fine by the mechanism and is showing continuity when not activated so I guess it is a Normally closed? All solenoids work in test mode.
Next I unplugged the solenoid and switch, game still reports the short.
I disconnected the J3 plug from the board near the flippers. Still reports the error. I see nothing on this board which looks wrong and the diodes test good.
I then disconnected J207 and J209 from the MPU and it still reports the issue. So am I to assume that the problem is on the MPU?
