I wanted to have a better and more obvious Gozer on Ghostbusters, so I made an easy install Gozer mod from a store bought Gozer model.
To make it easy to install I took the original Gozer plastic piece, replicated it, and laser cut mounting holes on which I zip tied a store bought Gozer figure.
It looks amazing.
Installation is easy, just remove the 3D modeled city by removing the 3 screws that hold it in, that will give you easy access to the Gozer plastic.
remove the two screws, then remove the washers off the two screws, you won't need them. Put the new plastic with mounted in it's place and reattach the screws!
https://pinside.com/pinball/market/shops/1463-arcade-cabinetscom/09913-ghostbusters-gozer-mod
IMG_0338 (resized).JPGIMG_0339 (resized).JPGIMG_0340 (resized).JPGIMG_0341 (resized).JPGIMG_0342 (resized).JPGIMG_0343 (resized).JPGIMG_0344 (resized).JPG
