Quoted from swinks:every since the last update I had weird issues with the overlord and put it down to software update but no one mentioned they were getting the same issues so thought to look under the playfield and reseat all the connectors and then check the menu and low and be hold an error.
Having not paid attention to the overlord mech until now I am not sure what the problem is.
Anyone else experienced this issue ?
Any tips or advice would be muchly appreciated.
I did another check and seems to be the small release coil that is not releasing or a Node board....
bump bump
I checked the small release coil and the gap was quite large so dismantled and there is a small bracket with a small finger prong that is bent so straightened this out and in coil tests both work.
But when I turn the game on the prong post attempts 5 times to rise up and still getting the "device malfunction - overlord lock" error code.
I then ran a switch test and all switches seem to work except for the opto near the overlord prongs.
Could some one do a switch test and let me know if your fingers trigger the opto switch in switch test please.
Anyone experienced dead opto switches in this location....
14790DB5-42BC-4558-9857-A7BCF1D0A9FD_1_105_c (resized).jpegEAB0BFCE-6BD1-448E-8FC1-0645694BC2DD_1_105_c (resized).jpeg
