Looking for guidance on if this speaker hum I'm hearing is normal for a Williams Flash or is there something else I can chase down here. All sounds are working properly - it's just this hum that is most noticeable during Attract Mode. The hum does not get louder or softer when I dial up or dial down the volume. I know 1970's solid state pins aren't exactly high fidelity but the hum on this one is way louder than any of the others I've worked on before, including a 1980 Black Knight restoration I did a couple of years ago (same manufacturer and era). It's loud enough that when we're watching a movie in our home theater (which shares space in our rec room with my pins), we have to turn off Flash if it's not already off so the hum doesn't disrupt / distract the quieter portions of films.
I don't know how it behaved before the restoration as I got it in a heap of parts and never turned it on until I got to that point of the restore. You don't hear it during gameplay or over the constant droning sound effect playing in the background...this is only noticeable during Attract Mode.
What I've done so far:
- Sound Board was re-capped and a new pot installed
- Speaker is new, but I put the original back in as a test (same hum)
- All new ground braiding throughout the cabinet with dozens of checkpoints for continuity passing
- Ground braid contact points exactly match the way it was in this cabinet originally as well as comparison to other reference photos I've found online (including the lower cab ground strap to the wingnut in the backbox). I don't think I'm missing anything.
If ya'll tell me this is normal for a 1979 Williams Flash, I think I can live with it. But if I can reduce or eliminate this hum, I'm open to suggestion. Filter cap (where to put, what kind/size)? Replace other amp circuit components on the sound board (caps already replaced)?
Thanks...
IMG_5873 (resized).jpgIMG_5874 (resized).jpgIMG_5875 (resized).jpgIMG_5876 (resized).jpgIMG_5877 (resized).jpgIMG_5878 (resized).jpgIMG_5879 (resized).jpgIMG_5880 (resized).jpgIMG_5881 (resized).jpg
