Alright, so I'm going to start off by saying this isnt your normal Congo. This is a Congo I purchased that was put together... The playfield was removed from a working game many many years ago.. The populated playfield was sold along with a Congo conversion kit (security roms, translite, speaker panel etc) Basically the owner of the original conversion kit pulled the populated playfield out of the kit and swapped the one that was inside their working Congo to have a better playfield. fast forward years.. The populated playfield that was removed from the working game is now being installed into a brand new cabinet with an NBA Fastbreak harness to connect everything to the back box. When the game was delivered to me, It had an original CPU that was pulled out of a working "donor" Congo, a brand new Rottendog driver board, and an original AV board also pulled out of the working "donor' Congo. Now, everything was working EXCEPT when you would trigger the left slingshot switch, would also fire the trough eject. I spent hours trying to figure out where the short was, meticulously inspecting every single wire, connector, switch, diode, solenoid in the entire game. I couldn't figure it out. The trough eject fired like it was getting half the power( it could not kick the ball into the shooter lane).. Same with the left sling barely even flinching when activated. Everything else operated the way it should. I then decided to remove the MPU and take a look at the back..
I find a trace repair in the J206 column spanning from C14 to R70. (same row the slingshot acting up on)
I had been keeping in touch with the seller, and he agreed to allow me to swap the original "donor" Congo MPU with a brand new "untested" Rottendog Mpu, and we made a trade deal where I would give him the original "donor" Congo AV board plus some cash in exchange for a Pinsound plus board, WPC95 harness kit, a WPC89 DMD controller board (Pinsound's harness will allow you to use old dmd boards with their soundboard for 95 as a work around to not having the OG AV board) Pinsound speakers and sub.
*back at the machine, I install the new Rottendog MPU, and the WPC89 DMD controller board alongside the new Pinsound plus board with the appropriate harness from Pinsound. I triple dog check every single connection over and over again just to be absolutely positive everything is where it should be before powering it up. Upon booting it up, I have a DMD displaying, CPU working, and Pinsound also working. Once I skip the "factory settings restored" screen.. The machine goes into attract mode. Finally I close the coindoor which activates the high power for the first time since install and immediately.. all 3 flippers,upper left post, and mystery eject lock on. I was preparing for the worse.. so my finger was on the power switch when I closed the door just incase something like this happened, so it was only locked for .002 miliseconds before shutdown. So now I have different issues... after doing some processes of eliminating everything one by one.. I unhook every thing down to just the Driver board... No matter, what it wants to lock on if connector J119 is plugged in.. I unplugged the connector.. and reconnected everything back... I have a working display.. pinsound.. and game (essentially) but I have no flippers, trough eject, pop bumpers, mystery eject, upper left post, slings, or pops.
Back in switch test... I also realize that I do not have flipper optos, or eos switch closures. I've pulled everything out.. tested Diodes on The driver board with my Fluke 87 DMM... All have a .5 reading. Ive checked every single fuse off the board and found nothing blown. Ive flipped the cpu to driver 3 inch ribbon cable as I saw Chris Hibler's AFM runnin a Congo MPU with a Rottendog WPC95 driver board had its Red strip at the top while connected where as mine was on the bottom since I got the machine... I've read every single post on Pinside about wpc95 rottendogs, Ive searched RGP archives, and even Reddit r/pinball and I'm lost... I need some ideas... tips... Maybe someone has had this before... maybe not. There are so many weird factors in play I know its not going to be straightforward but Im down to try / test / work on anything that may help.
Thank you for reading... And I appreciate any advice here.
