I think I'm screwed, literally and figuratively. My Flash Gordon pf swap was going so well and I was so close to being done. Then this happened. This is the bottom end of the launch ramp. What kills me is I had the original ramp installed an decided to swap to a shiny new ramp and also new #4 screws. The new screws were 1/2" rather than 3/8" and probably crappy metal, so the head snapped (yes, I pre-drilled). Only thing I can think to do is us a Dremel to grind out around the broken screw just deep enough to get a needle-nose plier on the tip enough to back it out. Any other suggestions?
