Quoted from MiniPinHead:Did you use retailers for the posts, or did you find someone to make any for you?
I bought as many as I could that matched from retailers. I have gotten some used ones recently. I still need more though. Just put up an ad. I need to figure out exactly which ones are still missing, now that the weather is getting warmer and my bones don't ache as much.
Having a beautiful 70-degree day here on the East Coast (MD). Got back to work on my Doctor Who #3 build. I installed all the posts, rubber Orings, and plastics on top of the PF. I hooked up the Trap Door on the left side and the one-way gate on the right side from the shooter lane. I have the MPF all built but will not install till after the PF is in the cabinet. I need to buy a cabinet and head. I have the decals and parts to build it out. I have all the coils installed and wired up to Molex connectors. The next big step is removing the wire harness from Dr Who #1 and match it up to my rebuilt harness, so that I can get the right lengths to match up to boards in the back box. Maybe I will just remove the connectors to the backbox and remove the PF #1 to match up wire lengths. More to come...
432612097_7749598251731056_8975949391867158286_n (resized).jpg432634574_7749598628397685_223134258309380004_n (resized).jpgI am working on getting both Ramps installed with all the different size posts. I got real close and then found I had a 8-32 hex post and a 6-32 stud plate next to the Tardis. $12 shipping for the right parts as I want to move onto the next step.
DSCF3020 (resized).JPGDSCF3023 (resized).JPGDSCF3024 (resized).JPGDSCF3021 (resized).JPGCoil wrappers are here:
https://www.pinballrebel.com/pinball/cards/coil_wrappers.htm
Select the one you want, right click open in a new tab.
In the address/url box backspace out the underline and the word text, and hit enter, you will get williams logo labels to print yourself on colored paper or in color if you have a color printer.
I am fighting/building a PF wire harness. I have one Dr Who torn apart, measuring wire lengths and figuring out what Molex back box connectors I need to hook into which wires. I am following the existing harness and also referring to the manual. I was missing a Violet/Black wire in the 9 pin Molex of J130. After lots of looking at the existing harness, I found it is a 6 foot wire 22 Ga that runs from J130 to a 3 pin connector that goes to the Knocker. Need another order to WireBot. I have a list of 8 wires I need, (Browns and violets). Pictures to follow in the day light.
Quoted from Tophervette:I am fighting/building a PF wire harness. I have one Dr Who torn apart, measuring wire lengths and figuring out what Molex back box connectors I need to hook into which wires. I am following the existing harness and also referring to the manual. I was missing a Violet/Black wire in the 9 pin Molex of J130. After lots of looking at the existing harness, I found it is a 6 foot wire 22 Ga that runs from J130 to a 3 pin connector that goes to the Knocker. Need another order to WireBot. I have a list of 8 wires I need, (Browns and violets). Pictures to follow in the day light.
Don’t forget to reference the Parts Index. It lists the wire by cable, wire color, gauge, and length (inches).
https://www.ipdb.org/files/738/Bally_1992_Doctor_Who_Parts_List.txt
Might not be stock to what’s in an actual build from the factory, but it’s the next best thing. Lengths in the indexes are almost always longer than stock. Figured it might be useful for you to reference, instead of measuring wires in a harness
Quoted from MiniPinHead:Don’t forget to reference the Parts Index. It lists the wire by cable, wire color, gauge, and length (inches).
This is not his 1st game.
Game number 3 ! its gonna be AWSOME!
Thanks for the link. I printed this list out a few years ago. I even color coded many of the major entries and put topic headings as they are grouped relevant areas. I have spent hours reading this list looking for a certain part # only to find out that it is not available anywhere. I am comfortable making substitutions or even modifying parts to reach an end goal. Like you, I label everything. I make lists of what I am doing, colors, sizes, part #s. Even though I am duplicating what is in the manual, it helps me to learn and stay on track of where I am at in the build.
Quoted from Tophervette:Thanks for the link. I printed this list out a few years ago. I even color coded many of the major entries and put topic headings as they are grouped relevant areas. I have spent hours reading this list looking for a certain part # only to find out that it is not available anywhere. I am comfortable making substitutions or even modifying parts to reach an end goal. Like you, I label everything. I make lists of what I am doing, colors, sizes, part #s. Even though I am duplicating what is in the manual, it helps me to learn and stay on track of where I am at in the build.
Just didn’t want you painfully measuring a wire through a harness if it would be easier starting with the Index wire length and then verifying I pictured you tracing a wire through a thick harness and shuddered
Wire-Bot is the way to go
Progress...
I really do like stripping wire, crimping connectors, and figuring out where the wires go into Molex connectors. However, this PF wiring harness is kicking my ass hard. Last year I had already added new switches, lamp holders and plugs to the Playfield itself. figuring out the back box end of the harness is a challenge. I am missing wires. I cannot tell the difference between gray stripes and violet stripes. Faded Red and orange stripes are also too similar. I admit to being partially color blind, but I can tell my primary colors.
Back Box Connectors:
107 completed
118 To Do
120 To Do
122 To Do
126 completed
127 Partial - need Brown wires
130 Partial - need Violet wires
133 To Do
137 To Do
207 Partial - Can not read colors on wires, need to trace them out with VOM to discover.
208 completed
902 completed
907 completed
3 pin Knocker cable - need Violet wire
2 pin PF glass switch cable - need to build.
Im color blind.
Its easiest for me to KNOW that there are only 8 colors that Williams/Bally used.
The switch and lamp martix charts tell me the colors by their locatation.
This information translates whatever colors I see to a workable scenario.
It really does not help at all to have someone help me identify the color wire.
Since that person has no reference, that there are only 8 colors, they call out colors that arent even on the list.
So, its best for me to make up the colors in my mind (and not even name them as such) and just go with what I see and where the wires go.
I dont seem to have any trouble at all.
However I DO rely on packaging labels to make up new harnesses, and DO ask for opinions on say, orangy red vs dark green or yellow vs yellowish green colors.
With the help of the Switch Matrix in the manual. I am tracing and verifying connections to all the switch, lamp, coil connections.
All Playfield wires are accounted for and terminated with Molex connectors and labeled. Installing bulbs in PF. I will need to buy more at Pinfest Allentown in 2 weeks.
Quoted from Tophervette:All Playfield wires are accounted for and terminated with Molex connectors and labeled. Installing bulbs in PF. I will need to buy more at Pinfest Allentown in 2 weeks.
I’ll gladly pour over as many photos as you’re willing to post Labels included
This page was printed from https://pinside.com/pinball/forum/topic/bally-1992-doctor-who-restoration-build/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
