Hi i have a problem with my pong table that I bought used,
the ball is not served at the racket as you can see at the video and it changes the direction in play. I never saw a pong game where the ball changes its way haha... that can't be correct right ? :
https://www.dropbox.com/scl/fi/lptzjb0jau9fcfe5ilxsy/IMG_6339.mov?rlkey=dcb15ukuitjzbpbmbxn7vxorr&dl=0
is that because the belts are not tight enough ?
also the x axis is where wobbling/loose ... is that normal ? how can I fix that ? :
https://www.dropbox.com/s/4ytmv67tg09mydm/IMG_6340.MOV?dl=0
maybe the rollers are to worn ?
i also have a red light at the multimedia board.
is there a way to check if the 4 sensors are working correctly ? they are not checked in the button test.
can I tighten the y belts by loosing the screws at the second picture ? or is it the only chance by buying that adapter for the screw holes at picture 1 ?
greets
Bildschirmfoto 2024-04-18 um 19.20.57 (resized).pngBildschirmfoto 2024-04-18 um 19.21.08 (resized).pngBildschirmfoto 2024-04-18 um 19.21.21 (resized).png
