Quoted from MarkRan:I'm a first-time PinSound owner and just installed a new PinSound Neo in my Data East Star Wars. It works but the sound is pretty jarring. The high-end is shrill and piercing while the mid-range such as voice callouts is low volume and muddy. The bass out of the cabinet sub is good. I'm using the "SWDE Original Trilogy Ultimate Orchestration" which is highly regarded by users in the DE Star Wars Club. In fact, I bought the PinSound because I've been running this same sound pack on my virtual pincab from a PC through a $20 amp to cheap speakers very similar to those in the Data East cab (4" backbox and a 5" mini sub) and it sounds great (ie full frequency range).
Plugging headphones directly into the Neo also sounds substantially better in terms of the high-end/mid-range imbalance, so I ordered a pair of $70 4" Kicker back box speakers which have gotten good reviews here on Pinside as upgrade speakers to replace the Data East originals. The new speakers have very slightly better overall quality but the same issues with shrill high-end and weak mid-range persist so I suspect it's something to do with the amplifier on the Neo. The audio sounds wrong in a similar way to when a crossover is set at the wrong frequency or something like that. I don't think so many DESW/PinSound owners would be raving about this sound pack if they were hearing what this Neo board is putting out. And most of them have original OEM speakers too.
* Is the crossover something that's under user control?
* I think the sound pack was probably created on an earlier model of PinSound. Do sound packs need to be modified to sound correct through the Neo's amplifier?
* I understand it's possible to edit the sound pack and I assume I could try applying equalization to fix what the amp is doing to the sound but it seems odd I'd need to do this (and perhaps I'd be wasting time correcting the original source files when the issue is really in the configuration or hardware). Is there some easy overall equalization parameter I could adjust in the sound pack as an experiment or is the only way to edit each audio file individually?
We were so excited to get our beloved DESW playing the original John Williams score (like our Vpin cab) in time for hosting league night in a couple weeks, so this has been really disappointing. Any thoughts on how to troubleshoot this would be appreciated.
I bought the Plus version as well due to the EQ.
With that said, I'd suggest you contact Pinsound support. Include pictures of the installation and the Pinsound diagnostic file that it creates on the USB stick.
Let them know what you're experiencing and I'm sure they will try to resolve the issue. I'm not sure if it's something they can adjust in the firmware or not. But they do care that their equipment works as intended.
Nicolas from Pinsound has always responded within 24 hours when I've contacted them. There is a time difference so be patient.
