TP7 shows less than 1 volt. LED5 doesn't light at all. Prior owner replaced all BRs and caps. I pulled the board last night, replaced BR5 since I had a spare that's rated higher anyways, and all other game functions are working fine except flashers. Reflowed cap contact points. Beeped out continuity from the input pins on J102 through the fuses to the rectifier, to the test point, and then to the pins on J107. All seems fine on that front. Couldn't find any evidence of cracked pins.
J102 Pins 1 and 2 measure ~18.5 VAC with red on the connector pin (Disconnected from PCB of vourse)
J102 pins 3 and 4.... measuring like 4 or 5 VAC. What? Is it possible this is completely the problem and there's just not enough power here to get through the cap and the rectifier, or should I be looking elsewhere on the driver board? It's not like there's a whole lot to this circuit..
