Quoted from Cliebo:Looking to purchase my first machine and I’ve decided on a Godzilla premium. The problem is I need to lose 3-4 inches in total height on the machine. Does stern or anyone make smaller legs or is my only option to cut the existing legs down?
Thanks in advance
4 inches is a lot, and as others have mentioned, you need an inch or two inches of the back leg levelers screwed out to get 6.7 degrees of playfield pitch for proper play. My Godzilla top of the backbox is 76" when properly leveled.
So, your upper boundry is 71 inches. You'll need 5" shorter legs if your floor is very level, and further adjustments don't need to be made to the screw-in leg levelers.
As others have suggested, there isn't really a pre-made solution for this much change in height.
I'd buy the unpainted legs from pinball life:
https://www.pinballlife.com/segastern-raw-legs-set-of-4.html
Because the cutting and welding is going to ruin the paint anyway.
Then have your welder spray some black paint on them. Raw legs rust insanely quickly.
Depending upon your situation, it may help to know that the machine 'leans forward', and the top of the backbox is 7 inches or so away from the wall. I had a customer with a shelf that was just a bit lower than the height of the pinball so they thought the machine had to fit under the shelf... but we pulled the machine an inch away from the wall at the leg levelers, and the top of the backbox didn't touch their shelf. It wasn't under the shelf, it was in front of the shelf, but the customer was happy.
